Sculpting long, braided hair
TheXtremisT
Thu Feb 18, 2021 5:05 pm
Hi everyone.
I am making a wrestler for a customer, who has thin, braided hair.
I would like to know if anyone has any tips on sculpting hair like in the image below?
I find it tough to roll the sculpt into thin strands. But how would you guys do it? I almost wish there was a texture mat to roll the texture onto the sculpt.
Thank you
Mighty Tom
Re: Sculpting long, braided hair
Fri Feb 19, 2021 10:27 am
Do a google search for Green Stuff roll maker, it might work for what you want.
mr_mxyzptlk
Fri Feb 26, 2021 5:29 pm
First suggestion would be to try and find a figure with similar hair that could act as a donor. That might give the sculpt a little more flex.
Next suggestion would be to try a "roll/pull/twist" technique.
Roll your sculpt into a thin "snake", then pull the opposite ends apart thinning out the snake. Then twist the ends so the sculpt starts to get rolled/twisted look. This can work for braids or dreads which will all look pretty similar at this scale.
Sent from The Void using My Incredible Mind
Liney
Mon Mar 01, 2021 12:00 am
How about braiding some thread/separated strands of wool/yarn then coating them in a glue like elmers or mod podge? The scale should be about right, and the glue would allow them to take paint and stay flexible.
I would imagine you could also braid them around a fine jewellery wire which could be poked into a drilled hole in the scalp for better stability.
TheXtremisT
Wed Mar 03, 2021 12:05 am
All great suggestions. Thank you.
I'm gonna try first with the roll maker idea, see what textures I can create.
Then will try your other suggestions if needed.
Wed Mar 03, 2021 5:03 pm
Mark Henry or the Fiend would likely be great hair donors.
